3.2 wont start
My 3.2 won't start. I dropped the motor to do some transmission work and replace the clutch. Motor is back in the car now, cranks but won't fire.
I have no spark and no injector pulses (I tested using a noid light) Quote:
#8 scares me... Any thoughts? |
What condition are your sensor plugs? IS the plastic insulation craked or missing. I once had the sensor ground out on the bracket and the symptoms were the same as you are seeing.
one of my crank triggers got me like this when i reinstalled my 3.2, ended up being that one of the sensors was a hair too far away to pick up a good signal, i readjusted the sensor mount and she fired right up.
I suppose that could be it. I didn't realize there was adjustment in the sensor mount... |
Make sure you didn't flip the two sensor wires. I wouldn't touch the mount unless you are absolutely sure its your problem. Try flipping the two connections first.
Check for vacuum leaks also. I learned this one the hard way. If you are not pulling enough air across the air flow sensor, its not going to start unless you push the accelerator in far enough to open the throttle body and bypass it. |
DME relay unplugged?
+1 on the sensor air gap. I left mine too big after a clutch change and could only start it by running jump leads (booster cables) from another car. And when it did run it would rev to 4.5k and splutter big time on WOT
+2 on the sensor air gap. The bracket is adjustable, when you remove it you need to readjust the the gap to have .8mm between the end of the sensor and the toothed wheel.
-Chris |
Did you happen to set or trigger the alarm?
The alarm cuts ground to the DME relay according to the wire diagram. To be sure it wasn't dme relay related, I completely bypassed it by using a jumper wire to send 12v from pin 30 to pin 87 and 87a. |
I'm going to get a multimeter with AC volts on it and check for voltage from the ref and speed sensors. That should confirm the theory of them having too much gap. I really hope it's that simple! |
something like this happened to me...
I had forgot to connect the group of brown ground wires to the #1 runner....they drop down out of sight....hooked them up and all was fixed....most likely it is something simple like this.. what was funny...I went and asked my mechanic....he knew what it was without looking...the worst thing is if this group of wires is making contact somewhere and when you drive it falls off... |
| All times are GMT -8. The time now is 03:28 PM. |
