Stressed Member
Scott Clarke's Avatar
Which Goop for Cork Gasket?
I'm installing the cork gasket for the oil tank oil level sensor, which uses a cork gasket. Should I use any sealant, or just install it dry?
Thanks,
-Scott
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 10-28-2006, 08:10 PM
Gearbox's Avatar
Factory installs dry. Just don't tighten too much to split the cork gasket. A thin layer of RTV doesn't hurt, but makes it harder to replace later. Hope this helps, Allan
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S.
www.TheLolaRegistry.com
"When you think you are in full control, you're just not going fast enough."
Old 10-28-2006, 08:20 PM
Stressed Member
Thanks, Allan. Dry it is.
-Scott
Old 10-29-2006, 10:02 AM
