remote key lock
I have a 99 911 Carerra Cabriolet and the remote key stopped working. I've changed the battery but no luck. Where do I turn next? I can't seem to find any fuse or reset and the owners manual isn't much help.
I don't know if this will work on a P-car, but when this type of issue has happened with a Saab, disconnecting the negative battery terminal for about 15-20 minutes has done the trick. I would assume, of course, that you checked fuses, etc?
Steve |
| All times are GMT -8. The time now is 06:53 AM. |
