Front bumper 'smile' removal question.
I have a new (used) front bumper 'smile' to go on my '85 carrera.
How do I get at the screws ( 4 each side ) to remove the old one? The 4 from inside the trunk look easy. I wonder if I need to remove the valence or bumper to get at the others from underneath? Thanks. Chris
1985 Carrera 3.2 1986 944 Turbo ( now sold ) 1978 MG BGT 1995 TVR Chimaera 4.0V8 2009 Mazda 2 Sport |
Senior Member
Front bumper needs to come off
78 Euro 911sc Targa 03 Hayden SCWDP |
Thanks for the reply.
I thought it would be more complicated. Which bolts remove the bumper? Do I have to remove the rubber strip at the front first? Chris
Remove the front rubber strip Two screws, one at each end and the front strip is gently pryed from the bumper. Now unblot the four bimper bolts and your home. The front bumper is usually very stuck to the robber that is sandwiched between the bumper and the bumper shocks.
Keith Epperly 87 slant nose turbo look carrera cabriolet |
there was a thread on how to take off the front bumper...there are a few tricks
Sold: 1989 3.2 coupe, 112k miles |
Dan in Pasadena '76 911S Sahara Beige/Cork |
Senior Member
you will also have to remove the screws holding the bellows to the bumper / valance
Success! A clean smile is much nicer than a 'toothy' grin!
Main nuts were very rusted, and bumper was well stuck to rubber on the bumper mount 'shocks' Got the nuts on the bellows each side. A bit fiddly to reach on rh side with oil cooler there. tiny 8mm spanner and a few minutes and they came away. Headlamp washer pipes were a bit harder to remove without destroying the plastic. ( By the way, how do I activate the headlamp washers? I have never seen a switch for these...)
A little late on this one but for future searches... I have instructions in pdf format and will be happy to email them to anyone in need.
Eric
'79 SC Silver over Black... Sold |
Eric, I'd like to have a copy of those instructions. PM sent to you with my email address. Thanks for the offer, Dan
pdf sent. I actually recieved thses instructions from a fellow Pelican but can not remeber who :-( Anyway, hope it helps.
Eric
Eric
Very timely - I think I need a copy as well. I've just tried to get the bumper off and its well stuck. I'll send you a PM Thanks Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83 Keep buying parts to make it look older. Mid life crisis is now in its 12th year. |
Could someone send me the pdf as well? I can PM an email...
Thanks, Skip
1972 911T 1972 911E "RSR" |
Sorry if I missed anyone.. Please PM me your emails and I will have the pdf out promptly.
Eric
Eric- I sent you a PM a few days ago. Need me to send another?
I really appreciate it!! - Skip
Does anyone have the pdf of the front bumper removal instructions mentioned above? If so please send it my way, I'm removing trim in prep for a repaint. Thanks.
83 SC Euro Guards Red/Pearl White sport seats |
WOW!
Just what I need. Can someone send me the pdf file on the front bumper removal....please? I need to change out my left front blinker housing. ![]() Please pm me and I'll send you my email addy. Thank you!
Woody Slow n Fast 1984 Guards Red 911 Carrera |
