SWB seat belt attach point rust
After I removed the padding in the rear of my 68T, I found (center of the picture) an unusual rusted area -- one of the seat belt attachment points on the inner wheel well. It's hard to see clearly in the picture, but the metal wall in the passenger compartment has dissolved, leaving the bolt only attached at the top and bottom of the inside wall where it can be easily twisted right off the welds.
Protruding out and into the wheel well area is a oval reinforcing metal "bubble" spot welded onto the wall where the bolt is welded. There is a hint that something was attached to the backside of the "bubble", but it rusted into dust. Anyone know what this assembly should look like?
Bump!
I am just gonna have to interrupt and ask you. Is that a DB4?
Austin Healey 3000 Mk I
Mike, I am not ignoring this request, but am having a hard time finding a picture of that spot. But working on it.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Thank you very much!
Here are pics of that spot on my Karmann built '68 Normal tub (didn't think they had a "T" that year, did they?)
Lots of undercoating in the way of seeing any detail, but it is just an oval sort of cupped backing plate welded over the lug. passenger side: inside view for reference: HTH, Mike. TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Thanks Tom!
That's just what I was looking for. Mine is a Karmann -built T -- sold only in Europe in '68. Is that a drain (pointing down) on the bottom of the cup? And is the thing sticking out of the "cup" center in the first picture a bolt? |
There is supposed to be a plug to protect the threads. The plugs I have seen have been plastic. With the undercoating they do get hard to remove. The thread is 7/16 fine thread. Universal for seatbelts. It is not metric. Hope this helps.
69 911 2.3Ez 85 928S |
TT
