Thanks guys.
Once I know of my mechanics' assesment I'll PM you Henry for more details. Simon
85' Carrera 3.2 02' Mazda MX5 |
mine came in the other day and wow they look VHQ in deed. very happy . soon I will run them but it may take a bit to get the engine back together
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Try not, Do or Do not
A head up on an old thread.
We have discontinued the used of QSC cylinders on all but our 906/custom builds. The 86mm Nikasil cylinders are incorrectly designed and are prone to catastrophic failure. When we approached them with this design flaw, they dismissed my concerns as inconsequential. After we had two engine fail during the first 15 minutes of break-in, we recalled all the 86mm cylinders we so;d. A complete refund was included in the recall.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Does this affect only the 86MM parts, or does it include all of their other parts? Finally, kudos to you for stepping up and initiating a recall/refund program! |
PCA Member since 1988
Thanks for the info and for doing that, Henry.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
