Door stay issue
Thought I'd seen a post some time ago regarding loosening up the tension in door stays. I'm installing the reinforcement kit and want to ease up on the pressure as well. Any help?
Driving member
I did this repair several years ago. Here is a link to a thread that addresses this.
Door stay help Just an added note, the repair has held very well. I did it about 6 years ago.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Thanks, Jerry. I will use the Dremel.
Me too. I put in the door-stay reinforcement kit, and a new door stay, six months ago, and ever since, it has clacked so loud--two times on a full door opening--that 911 people keep telling me "You need to install the reinforcing kit." I already have, but obviously the door stay itself--probably made in Mexico--is way too stiffly "humped."
Thanks!
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
While I was at it I soaked the door stay in mineral spirits, then blew it out with air, then soaked it in LRC. I'm not sure if it helped but I couldn't help but notice a lot of grime coming out of the piece with the plastic/rubber resistors.
1991 GP White 965 |
