dim high beam indicator
I found several old posts on this subject, but no resolutions. So, I thought I'd re-check to see if anyone had found a solution.
The high beam indicator (blue light on tach) on my '83 RoW SC is barely visible. It has a new bulb and seems to illuminate as bright as any other bulb - tested by pulling and grounding the case and also checked the ground/operation while inserting back into the housing. Curiously, the indicator on my '79 930 is visible. Not bright, but visible. Thanks, Skip |
| All times are GMT -8. The time now is 10:55 AM. |
