69sporto's Avatar
front struts. Help
Hi again,
I have a '69 T sportomatic 911 under heavy restoration. Somebody told me -Grady?- this car has -or had- the Comfort option: hydroneumatic struts, without front sway bar, big brakes... like the E model.
today I was taken out the strut inserts and found this nice gift. a custom inserts.
Can I use this struts with standard inserts?...
Do I need S-struts to keep the big brakes?...
what do you think?
Thanks,
Sergio
Goodbye Sportomatic, hello 993tt!!
Old 11-06-2006, 11:57 AM
That is a koni insert which is typically used with S suspensions. I think you need S inserts. Do you have the aluminum calipers? It is possible to have konis on a boge suspension but it is definetly more rare.
Old 11-06-2006, 12:02 PM
69sporto's Avatar
I think they are aluminium calipers. sportos had big brakes. I donīt know if this inserts are original..look at the metal rings itīs like an adaptation.
Old 11-06-2006, 12:14 PM
lwa lwa is offline
I think they "fixed" the h-pneumatic struts by adding spacers so the smaller standard struts would fit. They did this on my '71E. You should check if the can has torsion bars - or not.
Larry
Old 11-06-2006, 09:15 PM
69sporto's Avatar
No torsion bars...I guess.
works fine the adaptation of standard insert on this struts?
Old 11-07-2006, 12:05 AM
