looking at the wiring diagram, power is applied to to the WUR, thermo time valve and aux air reg. from the fuel pump relay. the power should be there when the key is on. lack of power here will effect all plugs the same.so u may have 2 problems. i didnt see a thermo time valve on the 76 diagram that i have but there is one on my 77.
also, use a "test light" for trouble shooting power, it is much easier to use than a multimeter. does the fuel dist. have screws beside each of the fuel line connections? if so, they adjust the amount of fuel to that injector. you could have bad injector seals on 4-5-6 making them run leaner than 1-2-3. check the fuel flow on injectors 1 and 4, should be equal. u could even swap 2 or 4 fuel lines on the fuel dist, if they will reach, put in new plugs and see if the "bad plugs" move. the dist is very expensive, try everthing before u spend the money on one. |
T77911S, the pressure for each line were apparently checked by both specialist tuners and were found to be good, although given some of the other aspects overlooked/incorrectly set maybe its worth checking again. I値l have to check tonight to see if there are adjustment screws on the fuel distributor, but I can稚 remember seeing them in the past (although I must admit, that without gauges etc, I知 reluctant to adjust anything on the FD). I値l also re-check the fuel injector seals on the right-hand bank as well.
Swapping the fuel lines is interesting, as I put new ones on when had the engine out. Any chance of an air lock or something coming into play here? Also, I have an option of buying a complete CIS system for around $200-300 and I am seriously considering buying one of these and just transferring bits and pieces on a one-by-one basis until the problem is resolved. |
Given Milt's comments about the engine being warm when I tried to test the WUR for current, I had another go this afternoon with the engine stone cold.
The result was that with the ignition off, there was no current measured. With the ignition in the start position (could hear the fuel pump buzzing), I could only measure 0.1 volts! Now to measure this I was pushing the multi-meter probe hard into the connector as 'arrowed' in this picture: http://forums.pelicanparts.com/uploa...1163412821.jpg Also, why is there a spare 'male' connector on my CDI (photo below): |
Oops, forgot the second photo:
http://forums.pelicanparts.com/uploa...1163413147.jpg So goven that I seem to have another problem (left bank running richer than right), is it safe to assume there is something wrong with the WUR (no current) and that this is the reason why the car is running so rich (about 5-6% CO2 level)? |
Check the flow rate of your fuel on your return line going to the gas tank. (Not the same as pressure or flow to injectors) That the problem reared it's head after fuel line replacement is suspect. Just because a fuel line is new doesn't mean it isn't be defective.
I had a similar experience once with my Benz. I had a fuel line replaced and shortly thereafter it started experiencing bucking and the motor dieing. I took it back to the shop and specifically mentioned that the problem occurred after the fuel line was replaced. They in their infinite wisdom chose to ignore this crucial piece of info and proceeded to start replacing parts at my expense without permission to no avail. When I asked if they had checked fuel pressure and flow rate they said no so I immediately told them to not touch the car anymore. I had the car towed across town to a reputable shop. Problem turned out the new fuel line was defective. It had an obstruction. I'm not saying this is your problem or for that matter your only problem because it seems like you have more than just one issue going on but it wouldn't hurt to verify flow rate from the fuel pump. The WUR should be recieving current while the motor is running. On the earlier motors it recieves current as soon as the ignition is on but on later versions the motor has to be running for it to recieve current. (this prevents preheating the element by accident on cold mornings) The connector shown in the picture for the WUR has one side that is ground the other side is the hot lead. The WUR is basically a valve that bleeds off fuel pressure from the system as the motor warms up therby leaning out the fuel mixture to the proper warm running condition. It is not bank specific and has nothing to do with what could be causing the spark plug soot problem. For the shop to confirm it's functioning should mean they checked pressure for cold and warm running conditions and confirmed it is working. The fuel and electrical systems are not bank specific. That one bank of spark plugs is sooty and the other side clean makes me suspect cam timing. Is this a recent development or has this happened in the past? In the picture of your CDI the extra terminal is redundant. Nothing to worry about there. Start with fuel delivery and confirm that it is up to spec. Also check for fuel contamination. Once fuel delivery is confirmed check spark. Each plug should be giving a good spark. Keep in mind that if you find the initial source of your problem it will still take a while to get the idle readjusted since the mixture screw has been messed with. |
bobby is correct, the WUR treats all cylinders the same. no voltage to the WUR will make it run rich. fix the power problem and see what youve got after that. i still think you may have an air leak on 4-5-6 or the injectors arent spraying enough fuel for what ever reason. the injector seals are easy to replace. i may have missed it, but what is the condition of the injectors..cleaned and check?
nice pics by the way |
Sheldon,
Bobby has voiced a thought I had also... You are running two different camshafts; can you identify if the sooty bank is the SC cam rather than the C3? I'd be trying to ascertain that the two shafts are truly identical. Do you know if the timing of these cams is identical also? If you can satisfy yourself that the cams are "identical" then you may have to re-time them - in the abscence of carbies or ITB's, I reckon that is the only answer to one bank being different to another. (If you need the tools - I've got 'em) Cheers |
I've been assured that the cams should be identical and that they are at the correct timings. From memory, the plugs were ok in changes undertaken prior to this (except strangley plugs 3 &4 were showing some signs of running rich). If all elase fails (no leaks from injectors etc), I guess that I'll have to pull the cams out and have them analysed. Keep in mind though that the car was running essentially ok prior to the engine drop.
This weekend I'll conduct more tests on the WUR and look more closely at the wiring loom as it does show some signs of deterioration in several areas. I think there are two issues at hand, wiring and air leaks. Exactly why they have chosen this point in time to fail simultaneously is anyones guess. |
Similar problems in my '73 - after a fortune in swapped parts, it turned out to be an inline (fuel) pressure regulator ($19). Check the fuel pressure to the CIS before you mortgage the house...
George |
Sheldon
Time to drop back a bit and look at this. First figure out if the changes for the worse were coincidence or a result of pulling your engine out and replacing the fuel line. Did you disconnect both fuel lines down by the transmission, or just one. If just one, I guess you couldn't have gotten them hooked up wrong. The fuel lines are tough to replace - sure no dirt got in when you were pulling it through? Fuel filter OK? And how about fuel delivery: disconnect the fuel line (maybe at the fuel filter?) and run the fuel pump, dumping the fuel into a container so you can measure flow. Time a few seconds or a minute's worth and measure the output and compute the rate. I don't recall fuel flow rates, but it ought to work out at least to say 69 to 80 liters/hour with no resistance involved as a pure guess. Someone will have a spec for this. If this all checks out, it is unlikely that the fuel line was the problem. But you have a fuel problem. Then recheck everything you had to disconnect in order to take the engine out. There aren't many of these, and I don't hold out much hope. But who knows - maybe somehow the 14 pin connector got messed up and that affects WUR current or something. If all seems OK (you think it is now, I gather), and you don't think anything got dislodged or busted during the engine R&R, then put aside thoughts that the R&R was involved, as at that point it may be best to assume coincidence. Unless somehow in the process you got dirt into the fuel lines downstream from the fuel filter. So now what. Well, you say it ran OK before, but then contradict that by saying the previous owner had had to fiddle with the fuel system, and maybe it didn't run all that well. Now what? Well, does your spark distributor check out pretty well? Advance (and retard, if it has that too) work OK? Etc. Sure, that isn't apt to affect right vs left side, but so what - it could affect running generally. Always best to check the spark side of things before the fuel side. Were those plugs new - replaced when you had the engine out? If not, why not put new plugs in to see if they quickly start looking like this batch? Next, myself, I'd follow the suggestion of your mate and swap fuel distributors to see if something in there is causing the problem. If something went wrong in there it is almost impossible to fix. He says he had very similar symptoms. Adjusting fuel distributors: there are adjustment screws next to each of the six fuel lines, but they each have a cap over them so they don't look like screw heads. And for good reason - most of us don't fuss with them as they set something mysterious called the differential pressure for each fuel line. But there is a test you could perform yourself without instruments: Get six baby bottles - clear glass (or plastic) with fluid graduations on the sides (or raid a chem lab). Pull all six fuel injectors. Stick each one in a bottle. Run the fuel pump and, with the air cleaner off, push up on the fuel metering plate. Then compare bottles to see if each one has about the same amount of fuel. If the right side ones that correspond with the really sooty plugs (and one of those left side ones doesn't look so hot) have a lot more, maybe you are onto something. Of course, the two left plugs with white insulators might be running quite lean due to a problem with their fuel supply, and the overall fuel supply has been richened over time to try to compensate. You could try to adjust those two until their flow was the same as the others, I suppose. Adjustment involves pushing on a spring that pushes on a little diaphragm inside the fuel distributor. I understand that these diaphragms can go bad. If a hole developes, the one affected doesn't do its job. Most of us never fiddle with them (I never have, but a buddy once did to fine tune his fuel flow - said it didn't make a noticeable difference). Substituting a known good fuel distributor might be preferable to doing this. The WUR should have +12V all the time the engine is running. When the engine is hot this is redundant, because conducted engine heat should keep the bimetal strip bent and doing its job increasing the control pressure. Without this current you will still have a rich mixture to start up with, but it will stay richer than it should longer until things heat up. However, surely the shop tested the WUR and found that control pressures at cold-start and over the warmup period and for warm running were within normal limits? If this CIS stuff is confusing, follow Michel's advice and look at Jim William's rennlist site: pictures, diagrams, explanations, Bosch troubleshooting chart. I'd not worry about the "mismatched" cams. The SCs only had one cam grind, so the fact that you have one from the original motor and one replacement from a later motor (is that how you read things?) ought not to matter. (Though one might wonder why a cam had to be replaced at all.) Cam timing is easy to check, however, so if worried you should do that at some point to see if both cams are properly set. If one side is out some, it isn't all that hard to reset it - it can be done with the engine in the car, though with some effort, like removing the muffler and some sheet metal, and jacking the car way up from the rear to keep the oil in the case. Bottom line - swapping in a known good fuel distributor may be the quickest way to get a handle on what is or is not causing the problems. After you are sure your spark distributor is working well - which you could also do as a swap job if you have someone nearby who can lend you his. And you did do the "glow in the dark" plug wire test, right? But a fuel distributor fault sounds to me like the thing that would be hardest for a shop to find. And maybe just sitting around while the transmission was being worked on was just the amount of time needed for something to corrode in there. All this is easy for a guy like me to say - I do my own work, own the CIS pressure tester (and ought to own an exhaust gas tester), and so on. Walt Fricke |
the lack of power to the WUR may be amplifing a problem you had all along, so fix that first.
i asked about the screws on top of the fuel dist. thinking maybe somebody turned them not knowing what they are doing, if u do have them, dont mess with them. u said u replaced fuel lines to the injectors, lets go back and look there. i cant see 3 bad fuel lines, but u never know. swap 2 of the lines on top of the FD or u can swap the left side injectors for the right side. u dont need to pull the cams to check them, just put a dial gauge on them. if u havent done it before, just make sure u understand how to read the dial gauge, mine were set up 15* advanced because somebody read the dial gauge backwords. ( the needle moves in a CCW direction as the valve starts to open so u have to read the small numbers that go in a CCW direction) |
Okay. When you drop the engine, you disturb two things - hoses and wiring. Sounds like you have a wiring problem with the WUR - hot wire 12V to that right away, and see if that changes anything. The WUR works all of the time - it's not really a "warm-up regulator."
The other thing is the most basic element of these systems - vacuum leaks. Spray some carb cleaner around the hoses, and the injector ports, and see if the engine idle increases even slightly. If yes, you have a vacuum leak, and that could be the cause of your problems... -Wayne |
check the connector to the relay board, u may have put it on 2 pins off, remove it and reconnect it
Thanks for the feedback evryone, this why this board is as good as it is.
I will systematically undertake checks of all the items listed here over the next week or so (unfortunately my schedule is very tight for the next few weeks), but I will keep you all posted on how I go. Thanks again everyone, particulalry T77911S and Walt Fricke for their very detailed an considered responses. |
IS this the cause of my CIS Issues??
Hi guys,
Well I went and pulled the CIS out of my car this weekend in readiness for sending the fuel distributor away to be rebuilt. Guess what else I found whilst pulling things apart!? A CRACKED AIRBOX and no gasket between the FD housing and the airbox! Have a look at these photos: Underneath the airbox near the inlet manifolds: http://forums.pelicanparts.com/uploa...1165036957.jpg [img] Same again: http://forums.pelicanparts.com/uploa...1165036973.jpg[/img] And again. This one opened up quite a bit with just a little pressure: http://forums.pelicanparts.com/uploa...1165036995.jpg And again: http://forums.pelicanparts.com/uploa...1165037015.jpg I can't believe this, no gasket betwen the airbox and FD alloy housing! http://forums.pelicanparts.com/uploa...1165037034.jpg I know these couldn't have happened just because I pulled the engine out (unless the airbox took a big hit - which it didn't to my knowledge), but they must be contributing significantly to my problems. I still think that I should send the FD away to be tested and more than likely rebuilt. What are you thoughts guys? |
It's hard to tell from the photos but if your airbox is cracked then that's obviously not a good thing. I guess it's possible that it could have cracked when R+Ring the motor.
What's a little more common though is splitting the rubber boot that goes from the throttle body to the air meter on top of the motor. It's in a very handy spot for grabbing a hold of when your trying to get the motor back in the car. They get old and less pliable with age and tend to split when you try to use them for a handle. How did you arrive at needing to send out the fuel dizzy. Was the system pressure off? Were the pressures to the injectors off? |
fix what u know is broken first, then see what works and does not work.
The cracked airbox needs to be fixed first. That will solve the majority of your problem.
How could a reputable shop not catch a cracked box like that? I would want some answers and maybe credit back some labor. Hope a new box and WUR with power will be your fix.
Good find on the cracks.
Wait with rebuilding the FD until you have a new airbox and gasket. Check the rubber boots for the intake runners and replace if necessary. Check the gaskets between runners and heads. With a new airbox, readjust the mixture and confirm that the WUR and AAR get power. Don't mix up the connections for Cold Start Valve, Warm Up Regulator, Airflow Sensor Switch, Auxillary Air Regular. |
| All times are GMT -8. The time now is 09:34 AM. |
