-   -   911 O2 sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/313691-911-o2-sensor.html)
rwjackson 11-07-2006 08:10 AM
911 O2 sensor
I have the single wire O2 sensor and the wire has separated, causing me to fail the low side of the emmissions test
can anyone help me on how to reconnect the wires and get that working. it is running rich.
thanks
tonythetarga 11-07-2006 08:33 AM
Do you mean it has been cut? If that is the case, you should be able to splice in a piece of wire and re-connect the two.
If the wire is broken at the sensor, I have a spare I can give you if you pay for shipping. The wire I have on the end is only a few inches long and will need to be spliced in, but it will work and is an OEM Bosch unit that came with a cat by-pass pipe I bought.
rwjackson 11-07-2006 09:14 AM
yes i would like to receive it. can i paypal you the shipping?
tonythetarga 11-07-2006 09:50 AM
Sure. Give me your address and I will send. Probably the best way is Priority Postage which should be about 4 bucks. I'll send it to you and then get back to you on that.
Glad you can use it.
rwjackson 11-07-2006 11:17 AM
6203 braesheather dr
houston texas 77096
thank you very very much
tonythetarga 11-07-2006 01:25 PM
I sent you a PM with the paypal info. The package was sent this afternoon. You should have it in 2-3 days.
glenncof 11-07-2006 02:31 PM
Crimp the wires, don't solder. Crimps from Radio Shack or maybe parts store. Get the right size for the wire.
porsche930dude 11-07-2006 05:45 PM
why not solder? I soldered mine because it was cut when i bought the car. I also reset the OXS unit behind the spedo because the light was on
