Enlighten me
Strange things, here is what is happening:
Ignition off: engage turn signals, they illuminate, but don't flash engage emergency flasher, they blink According to bentley, I do not have a flasher relay ![]() any ideas?
Donnie Currently Porsche-less..... ![]() |
Blinker Fluid?
Check for a bad bulb or bad connection/short at the socket. I don't see how you couldn't have a relay... ![]() If it doesn't blink on both direction I would look for said relay that doesn't exist.
Aaron. ![]() Burnham Performance https://www.instagram.com/burnhamperformance/ Last edited by BURN-BROS; 11-10-2006 at 07:20 PM.. |
Is this the Euro one sided parking light functioning? As for the flashers, I believe all cars will flash 4-ways w/o the key.
Band.
As Far as I know, that sounds like it's working Perfectly.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Seems the power should be switched for turn signals No euro lights
It is normal. Most european cars do that. It is supposed to warn other drivers that there is a parked car at the side of the road.
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Comon Milt, your old enough to know this one. This was a German thing for saftey. If the car broke down and you pulled over, you would turn the road side signal on to alert other drivers so they won't hit you while you were out looking for help. This way you didn't have to leave the key or keep the ingintion on, nor drain down the battery by the time you got back with help. Very helpful on those foggy Bavarian nights on the Autobahn. Those crazy Germans, you just got to wonder if they have this guy sitting around thinking this stuff up.
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S. www.TheLolaRegistry.com "When you think you are in full control, you're just not going fast enough." |
Warren Hall Student
My Porsche did this once. Turns out it was a drink holder.
Old Porsches don't like drink holders. They're kind of like girlfriends. They test you if they think you aren't paying attention.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Its a normal function designed into the 911 cars worldwide. In otherwords nothing is wrong.
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
okeedookee, I just re-installed all my lights, so I was concerned I wired something wrong.
Now in 993 land ...
That function is not for emegencies. It is for night parking, mostly in town, where the roads may be very narrow. You light the side that's out in the road. Lighting one side only (vs. all parking lights) will reduce current to the point where you can keep the light on all night without draining the battery. All German cars had this function.
George |
Thanks, Geo.
Thanks all, that actually makes good sense.
BTW they do flash with ignition on, so I guess bentley is wrong, now I gotta go check on this noisy muffler bearing.....
