Goldfinger
Mattcamp's Avatar
Porsche Crest 8x16" fuchs replicas......anyone ever see these up close?
http://www.***************/productpage.aspx?pid=110674&name=911%c2%ae+Alloy+Replica+5-Spoke
$250 a wheel for an 8x16" seems like a good price if these wheels look good and dont break.......anyone know anything about these???
911® Alloy Replica 5-Spoke 911® Alloy Replica 5-Spoke
$229.95 - $249.95
Application fits up to 1989 911 Carrera This replica of the standard factory wheel is manufactured using the superior low pressure casting method for a superb finish. Painted center and machine cut diamond finished lip area clear coated for added protection from the elements. Hub centric for a perfect fit. Made in Italy.
pop up description layer
Fits Applications:
911 ALL 1965-89
Old 12-19-2006, 12:39 PM
holtjv's Avatar
i wonder what the paddles look like under the black paint...I would give them a try--I don't have the energy to find real fuchs.
Warren Hall (Early S Man), 1950 - 2008
2006 Tri D675 Scorched Yellow
2006 Ducati Sport Classic mono SOLD
1979 SCWDP #0020 Talbot Yellow SOLD
Old 12-19-2006, 12:46 PM
I have them on my 78 and they are not an identical match to the real Fuchs wheel. Offsets match exactly, but the profiles of the 5 petals on the wheels faces are different. I had mine sprayed satin Black to match the real Fuchs finish.
They are ok if you want the 7/8 look right now (which I did when I bought my car). As soon as I come across some decently priced 8" wheels I will switch back to the real thing.
Old 12-19-2006, 12:52 PM
Bill is Dead.
cashflyer's Avatar
One step up above gravity casting, "Low pressure is the most common process approved for aluminum wheels sold to the O.E.M. market. Low-pressure cast wheels offer a good value for the aftermarket as well.
Some companies offer wheels that are produced under a higher pressure in special casting equipment to create a wheel that is lighter and stronger than a wheel produced in low pressure. Once again in the quest for lighter weight, there is a higher cost associated with the process."
This from GRM:
"...most any type of wheel (except wire) is strong enough for most types of racing. A good quality, pressure cast wheel, if made with the right material (T-6 aluminum), is plenty strong enough for a road racing car, and certainly for an autocross car."
However, the University of Wolverhampton, School of Engineering, says:
"Unfortunately the reliability of aluminium alloy wheels when using low pressure die-casting as opposed to high-pressure casting can be limited. Low-pressure casting allows greater flexibility in low volumes of production. However, this method can yield large variations in the quality of the castings."
Old 12-19-2006, 12:59 PM
Fake on left, real Fuchs on right.
Old 12-19-2006, 01:01 PM
the the is offline
The viewing angle seems to make a difference. They look ok in your pics, but they sure look fake in these pics:
[IMG]http://content.************************/main/111289/Replica%20Fuchs.jpg[/IMG]
The sharp angles on the petals look all wrong in that pic.
Old 12-19-2006, 01:06 PM
Bill is Dead.
cashflyer's Avatar
And one more item for consideration regarding cast wheels:
O.Z., largely considered a premium niche brand in North America, is a leading producer of professional racing wheels, as well as a supplier to European tuners such as Hamann and TechArt and an original-equipment supplier to Lamborghini. In an effort to increase its presence and popularity in the sport compact market, the company introduced the Superleggera model last year, using a combination of proven production technology and new processes.
Though the wheel is produced using conventional low-pressure casting or gravity casting, depending on diameter, the thin-spoke design is derived from O.Z.'s Formula One wheel designs, aided by the application of finite-element analysis and computer modeling. The wheel uses a proprietary titanium-enriched aluminum alloy for added strength and is lightweight. The final production step before painting is a shot-peening treatment to relieve surface stress and increase strength. The wheel is priced competitively with other conventional cast wheels, and in the 18x8-inch size, the wheel weighs a scant 18.5 pounds, ranking it among the lightest 18-inch wheels available to the general public.
(From a bimmer forum)
Old 12-19-2006, 01:07 PM
