Weaver's Avatar
Oil line removal and SSIs
Is it true to remove the thermostat to crankcase oil line ,you have to remove the thermostat to oil tank line at the thermostat also? I can see that removing the inside line at the thermostat looks very hard, not much clearance. I purchased a 36mm 12pt wrench from Pelican, but it cannot get into either end of the therm. to crankcase line.
Are there any tricks to only removing the one line, or do both need to come off?
Any helpful hints other than cutting?
Thanks for your time
Weaver
'88 911 Targa
'03 911 Turbo, X73 Susp.
'13 Panamera GTS
PCA member Central Indiana
Old 11-09-2006, 06:50 PM
Why not remove them both, if the alternative is cutting? I wedged a piece of wood between the body and the T-stat, it helped me get leverage on the line without torquing the thermostat itself. The position of the wood in the photos looks deceiving, but once you see the angle you can get on the nuts with a wrench, it'll make sense. Lots, and I mean lots, of PB blaster and patience before you attack.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 11-09-2006, 07:15 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Jgordon,
Very thoughtful!
I like you drain funnel as well.
Thanks for the pics.
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 11-09-2006, 08:22 PM
No problem, hope it helps.
89 Carrera 3.4
Old 11-10-2006, 11:34 AM
