Eye of the Toiger
Boxster Calipers Front V s Rear
This is probably stupid question, but because I don't know I have to ask.
I have a set of 4 boxster calipers to go on my 911 they look very similar to one another how can I tell which are front and which are rear. whats the defining difference?
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
Piston size, the fronts are larger. At least thats how my 996 brakes are which I'm putting on my 911.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
matt
also - at least for the front calipers - don't forget to reverse the lines to swap the Left caliper for the Right and vice versa. The boxster front calipers mount on the rear of the wheel not front of the wheel (like a 911) and they have leading and trailing cylinders of different sizes. can't recall if you need to do the same for the rear or not.
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
Does that impact the location of the bleeders???? That could be problematic.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
yes, you have to swap the lines/bleeders etc fron one caliper to the other in order to have the bleeders at the top of the caliper when mounted.
Eye of the Toiger
Yeah I thought so the adapters for the rear position the calipers at the back at 3O'Clock
Eye of the Toiger
I checked the part numbers as it turns out I have 2 pairs of front calipers
both pairs have 986.351.421.03 and 986.351.422.03 as part numbers. which are fronts. Rears are 986.351.423.03 and 986.351.424.03 so I need to find someone who has pair of rears they want to swap. I had these freighted al the way from the US.
Matty,
You may find the boxster all round would be too rear bias so you may be better off selling the extra pair and just get some Carrera rear calipers.
76 Carrera 3.0 (Group Sc) |
Eye of the Toiger
Yeah that is my thinking too
Eye of the Toiger
I can put on a brake bias value on the rear line that should sort it?
Eye of the Toiger
A local porsche wrecker in australia has told me that the boxster calipers I have a rears.
now the part numbers are XXX.XXX.421.XX and 422 respectivley on both pairs of calipers, rears are supposed to be 423 & 424 but he tells me they are rears that the part number don't matter cause its the same casting. Now I'm totally confused as to what I have if some one can help me identify what i have got
