Spring plate angle
To calculate spring plate angle do I use the door sill to get zero then calculate the angle off that? This makes sense but I can't find a direct reference in searching earlier posts.
Bill |
UFLYICU
Yes, the angle of the spring plate is dependent on a level surface, so checking the sill will yield a correction factor for an unlevel floor.
Here's the Wil Ferch calculator
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 11-13-2006 at 07:16 PM.. |
Thanks!
Bill M 88 Carrera 86 944 SP1 06 Cayman SPC |
