HELP!! Non working tach,speedo and fuel.
I would love it if someone could give me some wires to follow from somewhere to somewhere. What and where do the wires go on the gauge back and where does it hook up on the engine.
Thank you for any help.
Nathan
For my speedo, tach and fuel. Also, the lights are not working behind the gauges. What bulbs do I need???
Nathan
Old 11-10-2006, 10:22 PM
Gearbox's Avatar
Year and model would help
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S.
www.TheLolaRegistry.com
"When you think you are in full control, you're just not going fast enough."
Old 11-10-2006, 11:01 PM
Thanks, I dont know if I need a tool or if I am one.....
The car is a 77. It looks pretty simple but I am dealing with a car that once had a 3.0 in it. Now I have installed a 2.7 again but I must not have everything installed.
Nathan
1981 Delorean
Old 11-10-2006, 11:12 PM
Gearbox's Avatar
As I recall the 77 speedo is a cable driven unit, pull the guage and look to see if everything is connected, then see if it's connected on the other end by the engine/transaxle. Fuel guage is connected to the fuel sender on the top of the tank. Check to see if the float is free. I'm not sure if the tach on your car is driven by the coil or the speed sensors in the trans bell housing. But you can begin there. Usually all the bulbs don't go at once, I would check the fuses and light switch. Good luck Allan
Old 11-11-2006, 04:51 PM
