-   -   Brake Bleeding? Do it before or after changing pads ? (http://forums.pelicanparts.com/porsche-911-technical-forum/314566-brake-bleeding-do-before-after-changing-pads.html)
dan79brooklyn 11-11-2006 12:52 PM
My first time changing pads on my 79 SC Targa. I will be flushing the brakes while I'm at it...Is their any reason why I should be doing this in a particular order? After searching through threads on changing brake pads and bleeding brakes I did not find any comments about what order I should do the two projects.
I will be doing the gravity method for bleeding the brakes as it seems to be the simplest (I'm a mechanical novice).
Thanks for your comments on the subject, and any tips that will make these jobs go smoother.
jaydubya 11-11-2006 12:58 PM
If your pads are very worn, you will likely need to suck some fluid out of the reservoir to make room. I use a turkey baster for this. So change the fluid after you replace the pads to save the new fluid.
Don't know what you mean by gravity drain but get a pressure bleeder for a full flush. They make it very easy - well worth the $50.
LakeCleElum 11-11-2006 02:24 PM
Do pads first, then change your fluid. Then, the new pads will be seated against the rotors....
Dixie 11-11-2006 04:23 PM
It makes absolutely no difference.
That said, here's my personal preference…
  • Crack the bleed screw open so the pistons is easier to press back in.
  • Press the piston back and close the bleed screw.
  • Slide in pads
  • Gravity bleed the caliper a couple oz.s
  • Press the brake pedal once to seat the piston against the pad.
