I've been chasing a wet rear passenger side floor problem for a while now, and have found moisture on the inside of the rear window seal. I'm pretty certain this is my intrusion point and I'm guessing I'll need to R and R the rear window to fix it.
Until I can get to that I want to pull out the upholstery, seats, carpet, sound padding, and whatever else is soggy back there. Under the rear upholstered piece there's a piece that's sort of rubbery with hairy insulation on the body side. It's pulled free from the lower section but there's a long section just under the window that seems to be fastened down in a way I can't figure out. Could be one long bit of adhesive I suppose. Didn't find any fasteners through from the engine bay side. So, how does this piece come out? Thanks,
Dave '77 911S Rochester, NY |
Its glued in. Just pull. If you want to reuse it you may want to apply some heat from a heat gun so you minimize the risk of tearing. Good Luck.
69 911 2.3Ez 85 928S |
