don girard
Guest
Posts: n/a
3.6 911 engines
going to purchase a 3.6 engine to to bring hp up to around 300hp. The question is...what is the best to start with, a 993 or a 964? Why would one be better than the other?
Old 08-25-2000, 12:22 PM
JackOlsen
Guest
Posts: n/a
As the owner of a 964 engine, I'd have to admit to being jealous of the Varioram engines (1996 and later).
Of course, they're also more expensive.
Jack Olsen
1973 911 T sunroof coupe
http://members.rennlist.com/jackolsen/Jalopy.html
Old 08-25-2000, 03:46 PM
91C2wrencher
Guest
Posts: n/a
I can't help but ask, but 964 3.6 is rated at @242 hp and the 993 3.6 is rated at @272, the major difference that I'm aware of is the improved exhaust and the varioram intake, it would seem like no brainer, given that $ is not the problem to just use the 993 engine, drill the air box and install a chip (cyntex perhaps) and BAAM 300 horses(maybe)! I've been noodeling around with my 964 for years with chips and cat backs and K&N if I got a 10% improvement(questionable at best)I should be close to 270 hp. just my $.02....PS the varioram is really good at improving the low end torque, something the 964 is lacking.
Old 08-26-2000, 07:36 AM
RLJ
Guest
Posts: n/a
Buy the cheap one and dump the intake system put on PMO's, crank fired ignition change the cams and make some real HP. After I wrote this I thought about maybe you live where there are smog cops and have to pass the test. I'll go back to sleep.
Randy Jones
1971 911
Old 08-26-2000, 09:49 PM
