Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
North Coast Cab's Avatar
14 Pin Connector Wiring Diagram
I am installing a 3.2 in a race car which doesn't have the 14 pin factory connectr or wiring. The engine has the full wiring harness and DME. Anyone have a wiring diagram or an idea of what I need to wire through this 14 pin plug?
TIA, John
1985.5 944 GTS
Old 11-12-2006, 09:21 AM
Danny_Ocean's Avatar
Not sure if this will help, but a cursory search found this previous thread, complete with wiring diagrams:
Need help with wiring connector (993)
A search of the forums reveals 275 hits with "14 pin" as an exact phrase. Didn't have time to look through them all, but I'll bet you'll find what you're looking for!
Old 11-12-2006, 09:40 AM
Thanks. I did a quick search, but was hoping someone had done something similar and could save me hours staring at the schematics.
1985.5 944 GTS
Old 11-12-2006, 10:14 AM
Well, the research continues and the problem I have is that the car does not have a 14 pin connector or any of the OEM wiring harness. HEre are some threads showing the pin-out on the engine harness.
This is the 14 Pin Female on the 3.2 engine. Pin numbers are divided odd on top and even on the bottom. The pin assignments are as follows:
1. yellow - starter Kl.50
2. red - source from alternator Kl.30 ( or B+ )
3. green/black - Oil temperature Instrument
4. green/red - Oil pressure Instrument
5. red/green - from ignition.( Kl.15 ) to backup light switch
6. gray/brown - backup light switch to lights
7. free
8. brown/black - temp switch for fresh air blower
9. green/white - Oil pressure idiot light
10. free
11. blue - alternator control light Kl.61 ( or D+ )
12. free
13. black/yellow - power source for fresh air blower
14. red - source from alternator Kl.30 or B+
Or http://www.addictionmotorsports.com/WiringHarness.htm
So, who has installed a 3.2 in a race car?
1985.5 944 GTS
Old 11-12-2006, 03:12 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
