-   -   weber tuning and rebuilding question? (http://forums.pelicanparts.com/porsche-911-technical-forum/314726-weber-tuning-rebuilding-question.html)
hillelson1 11-12-2006 12:14 PM
what tools are needed to rebuild and tune the weber 40mm carbs. does anyone have an exploded diagram of these carbs?
thanks
-larry
tab tanner 11-12-2006 03:58 PM
Carb cleaner, screw driver, 1/4 socket set, carb sync,101 projects for your 911!!!!! and about 5-10 hours of time
2.7RACER 11-12-2006 06:43 PM
http://forums.pelicanparts.com/uploa...1163385766.jpg
hillelson1 11-13-2006 07:41 AM
thanks for the diagram you wouldn't by chance have a key for it describing what the numbers are?
wreckah 11-14-2006 12:40 AM
you will need a carb rebuild set with all the washers, rubbers, gaskets, ...
you will need compressed air too to blow everything out.
we did it on our 69T a few months ago, with no real technical background. Just take your time, nothing much can go wrong.
we took a lot of pics during the dismantling of the carbs, so we could always look back to see how a part was mounted in case we forgot :)
it took us about 1 day per carb, and that's including cleaning the whole body with toothbrush etc.. ;)
2.7RACER 11-14-2006 10:57 PM
http://forums.pelicanparts.com/uploa...1163573710.jpg
http://forums.pelicanparts.com/uploa...1163573767.jpg
hillelson1 11-15-2006 07:31 AM
thank you so much
T77911S 11-16-2006 09:39 AM
taking it apart and putting it back together is not the hard part. setting the mixture was always tough for me, with a unisyn the rest is easy.
go buy a 5 gal can of carb cleaner fron napa or advance, great stuff, but dont put anything in there with paint on it casue it wont be on there if u leaveit very long. good luck
