Question RED vs BLACK relays
ANY DIFFERENCE BESIDES COLOR IN ROUND 5 PIN
RELAYS IN FRONT FUSE BOX--THEY SEEM TO BE
INTERCHANGEABLE
77 TARGA
Old 11-12-2006, 04:05 PM
ianc's Avatar
The reds have a diode in them which does not permit reverse current flow. Can't remember if it's on the control circuit of the power circuit though...
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 11-12-2006, 04:07 PM
Early_S_Man's Avatar
Porsche Crest
The red relays have a noise suppression diode across the coil to minimize noise spikes on the power bus that would normally happen when the relay releases. Terminal #85 MUST be grounded -- not the + 12 Volt power signal, which is Porsche policy for all standard black relays, so ... thankfully, there isn't a fire hazard when a red relay is substituted in a socket for a black relay!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-12-2006, 06:03 PM
Jim Smolka's Avatar
The red relays have the diode which is called a "flyback" diode. It surves to prevent the inductive kick from a coil getting back into the 12VDC system.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 11-12-2006, 06:21 PM
