Paul W
Guest
Posts: n/a
Mystery Fitting - Engine Bay
Just completed my first repair – the replacement of the alternator in my car, and noticed an odd fitting which currently appears to serve no purpose.
Just forward of the oil filter, hidden from view, is a metal pipe that appears to be part of the bodywork and I suppose leads out into the wheel arch, next to the oil tank. At a guess it looks like the sort of fitting a hose would be attached to.
Can someone enlighten me?
Regards,
Paul
911T'69
Old 08-28-2000, 11:52 PM
Early_S_Man
Guest
Posts: n/a
Paul,
If the early oil tanks are similar to the later ones, I believe that 'pipe' with the nut attached is simply a brace for the underside of the dry sump tank ... I had to loosen the one on my tank in order to remove it for cleaning a few years back!
Warren Hall
1973 911S Targa
Old 08-29-2000, 12:14 AM
Paul W
Guest
Posts: n/a
Hi Warren, thanks for the clarification.
Paul
911T'69
Old 08-29-2000, 02:39 AM
Paul W
Guest
Posts: n/a
Paul
911T'69
Old 08-29-2000, 02:40 AM
