-   -   72T MFI questions (http://forums.pelicanparts.com/porsche-911-technical-forum/31499-72t-mfi-questions.html)
jims911t 08-29-2000 12:53 AM
72T MFI questions
Once again we have a problem. My recently reboult '72T with MFI seems to be getting no fuel to the injectors. The fuel pump delivers fuel to the filter, which delivers fuel to the injector pump, but after that, no luck. How do I check the MFI pump to determine if it is pumping fuel to the injectors? The injector pump was timed (3 times) according to factory manual specs, so I don't think the problem is there. Should the pump be primed in any way? The car has been sitting for about 6 months, so would bad/stale fuel pose a problem?
I've also heard that there is someone in the bay area who offers an early MFI manual for fools like me.
Once again, Thanks
Jim
warment 08-29-2000 04:14 AM
Jim,
Check out my webpage
http://www.geocities.com/william_armentrout/mfi.html
I have the Bosch "Check, Measure, Adjust" manual here. Hope this helps!
Bill
William Armentrout
1973 911T
2.7 carerra rs specs
campbellcj 08-29-2000 04:51 AM
Jim,
I think you're talking about Gus Pfister, Pacific Fuel Injection Service, South San Francisco. Might be worth a phone call to Gus if you can't isolate the problem.
Good luck,
Chris C. 70E (MFI just rebuilt by Gus...)
