-   -   Clutch Moan - Is this a problem? (http://forums.pelicanparts.com/porsche-911-technical-forum/315071-clutch-moan-problem.html)
ajmarton 11-14-2006 07:26 AM
My clutch makes a short and low moan as I ease into first and I was wondering if this is a normal characteristic or if this is the telltale sign of another developing problem? The PPI was clean. Any thoughts (I have a newly purchased 89 911 cab)?
MAS956 11-14-2006 08:35 AM
Mine is Similar
I guess the first question would be how many miles on the clutch?
My G50 tranny does something similar at take-off in first but sounds more likle gravel in s coffee can than a moan. G50's are known for being noisy.
Dirty Marty 11-16-2006 11:58 AM
I'd suspect that the clutch disc has been overheated and is glazed or burned as well as the flywheel. The pressure plate may be getting weak as well..........
I see a clutch job in your future
Dirty Marty
Fallbrook,Ca
don911 11-16-2006 12:03 PM
My G50 was doing that as well. Replaced the clutch and noise is gone. The PP was pretty beat up on mine.
