Rotate Oil Pressure Sender?
I've gotten my hands on a older right side heat duct that looks like it will fit fine if the oil pressure sender were out of the way. As you can see from the picture, it's currently vertical. If I could move it ~60 degrees toward the rear of the car, the duct would fit. So, can it rotate? If so, how?
Thanks! ![]() |
You can change the angle of the sender by loosening the fittings on the oil lines that go through the sending block at its base.
Excellent. Thanks for the quick response. I'll give it a shot tomorrow.
Kirk J. 78 SC euro |
