killsbugsfast
Guest
Posts: n/a
1986 911 Blinker relay
Where? Which? relay controls the Blinkers on the 86 911. Is it the center one behind the dash in the luggage Compartment area?
Jeff Baggett
Old 08-29-2000, 06:47 PM
BOBCOHEN
Guest
Posts: n/a
IF YOUR TALKING ABOUT THE THREE RELAYS BEHIND THE SPEEDO, THE CENTER ONE IS FOR THE SEAT BELT BUZZER AND WARNING LIGHT, IF YOU LOOK JUST IN FRONT OF THE THREE RELAYS NEAR THE BOTTON I BELIEVE IT'S DOWN THERE, HOPE THAT HELPS.
Old 08-30-2000, 01:34 PM
killsbugsfast
Guest
Posts: n/a
No, that one is for the Emergency Flashers only...and they work...only my blinkers are not working...and it's not a blown bulb, nor do I have the dual blinker lights lighting up on the Tach. Any more ideas out there?
Old 08-30-2000, 01:50 PM
RJM3
Guest
Posts: n/a
The new manual Bentley shows 4 relays behind speedo and is listed turn signal/emergency flasher relay...1;2;3;being power window relay;warning chime relay;windshield washer relay....good luck jer
Old 08-30-2000, 02:11 PM
