dweymer's Avatar
Relay wiring
I need to check the wiring of a relay, WUR relay to be exact:
Please tell me what goes to what pin?
Here is what I have:
Pin 30-switched positive, 11.5v
pin 85-gnd
pin 87-out to wur
pin 86-switched positive~.5v
Battery voltage is 12.58, as well as top fuse in rear panel, which I guess means to find and clean the grounds for the relay.
Donnie
Currently Porsche-less.....
Old 11-28-2006, 08:37 PM
leverpuller's Avatar
I'm working on the same problem
Old 11-29-2006, 09:30 PM
Banned but not out, yet..
RSBob's Avatar
Pin 30-switched positive, 11.5v = current power in from battery
pin 85-gnd = to ground
pin 87-out to wur = Power to accessory/light
pin 86-switched positive~.5v = power from switch coming in to activate relay
Old 11-29-2006, 09:38 PM
dweymer's Avatar
It has been confirmed that in my year '74, the power for pin 30 comes from the alternator.
Donnie
Old 11-30-2006, 05:42 AM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-30-2006, 05:03 PM
dweymer's Avatar
Thanks Ronin, that is how it is now wired. Apparently they changed from the Alt as a source of power at some point.
Donnie
Old 11-30-2006, 08:58 PM
