-   -   Spark Plug Gap with Pertronix Ignitor System (http://forums.pelicanparts.com/porsche-911-technical-forum/315454-spark-plug-gap-pertronix-ignitor-system.html)
Cordts 11-16-2006 07:29 AM
What is the suggested plug gap for use with a Pertronix Ignitor system on a 69T.. TIAhttp://forums.pelicanparts.com/uploa...1163690944.jpg
Howard M 11-16-2006 08:36 AM
The Pertronix just eliminates the points. The plug gap should remain as stock. If you install a CD system like Bosch or MSD the plug gap can be increased. Don't forget to reset the ignition timing (for the last time) after installing the Pertronix.
Cordts 11-16-2006 08:42 AM
howard. thanks for the reply.. I rean the gap up to .040 and it runs real well.. I thought that with the addition of this unit that I could increase the gap..
aigel 11-16-2006 09:26 AM
What Howard said. The Pertronix does not increase the oopmp behind your spark. It just makes the job of the points a solid state, non service item. To go to a larger gap, you'd need a more powerful spark, i.e. from a more powerful coil.
That said, the later cars have a pretty small gap too.
George
Cordts 11-16-2006 10:37 AM
Ok, that said.. I have the large Accell coil and Im running that big gap on this,, is that ok? I read some posts where I thought that a gap that big would not work,, maybe that was just with regular points..
kucharskimb 11-16-2006 11:51 AM
cordts
nice car.
you're not going to get a definitive answer off of this board about this. it's black magic voodoo to most.
determine the resistance of your ignition wires and coil, then call the manufacturer. give them all the information available. then see what they recommend. petronix does a lot of kits specifically for VW. they will have the answers you need. (909) 599-5955
if the gap is too large and the plug wires have too much resistance, then the intended spark energy may find the path of least resistance. ie you may get arcing between wires or between terminals in your distributor. some ignitions recommend low resistance wires and low resitance coils (which you have changed). beru wires are relatively high resistance. a final test is to run the vehicle in a blacked out area and look in the engine bay for stray arcs throughout the rpm range.
i run a crane xr300, ps91 coil, jacobs wires, ngk platinum and open the gaps to .045". all based on manufacturer recommendations.
Cordts 11-16-2006 11:58 AM
Kuch - Thanks.. will do.. Here to "Black Magic VooDoo" my friend..
Zeke 11-16-2006 12:20 PM
I'm going to bounce a theory off the wall for G&G and to actually be corrected by the ones that really know this stuff.
One thousandths gap for every 1000 volts with a minimun of .023 and a max of .060.
aigel 11-16-2006 04:42 PM
Generally, I would err on the small gap side and go with stock for your application. You will have reliable spark every time. What is the benefit of a larger gap? Will your mixture ignite twice as well, if your spark is twice as long? ;)
George
kucharskimb 11-17-2006 12:54 PM
hey, Kuch was my call sign...
randywebb 11-17-2006 01:15 PM
check out the spark gap info from Steve Weiner/Wiener on his web site
http://www.rennsportsystems.com/
kucharskimb 11-17-2006 01:50 PM
from Rennsportsystems.com:
The other big drawback is that you cannot use spark plug gaps larger than .032 without misfires. Its well proven and documented that plug gaps in the .040-.045 range make more overall power and result in better idle qualities due to the larger flame kernel and the resulting more thorough combustion process.
slightly ambiguous, but i think he is saying you can only go to .032" with a stock system. he lists several aftermarket systems in this writeup. it's my understanding that with one of the aftermarket setups, .040-.045" is optimal.
so i called steve... he agreed. with aftermarket ignition and matching coil and wires, .040-.045" is fine.
comments?...
