who sells gear sets?
Need to replace my 2nd gear set 85 915 gearbox. Who is a good source?
Thanks in advance. Simon
85' Carrera 3.2 02' Mazda MX5 |
Hey Doc,
Do you need the gear itself or the synchro assembly parts? Obviously, Pelican has the parts but I am unsure on the actual gear.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Wayne,
I need the gear. Simon
Need two 915 gear sets
I found these using the search feature. If used is workable, try contacting these persons.
Old Member
Simon
Email sent.
Clifton Brown https://www.mancalamarketing.com |
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
HI Simon what ratio are you looking for, I will have some good S/H gears in stock.
regards mike |
Mike,
My current one has multiple perforations through the hardening in almost every tooth! Need a good undamaged set. Stock 2nd gear. 1.83 I think? David, I've emailed Powerhauss and am awaiting response. Thanks. Simon
HI David there is 2 ratio's available for your box 18:33 (1.8333) box type No' 915/67,69,or72 and 18:32 (1.7777) box type No' 915/68,70 or 73, the gearbox No' and the type No' is under the diff near the clutch arm, should start with the type No' and then the box No' (915/72 or73 F00001 to 10000. I have just checked and I have only "HX" 18:33 not the 18:32, it has been used. The gearbox No' should look like this.
regards mike Last edited by MBEngineering; 11-16-2006 at 05:45 AM.. |
Hi all,
Just found out one of the suppliers of Powerhauss gears is 2 hours drive from my town! Also found out new gear sets here are pretty good value so going to order and see what we get. Simon
