Upgrades to car....
I'm doing the new exhaust, and got the turbo tie rod kit. I'd like to do SS brake lines, and upgraded torsion bars as well.
Suggestions on both? What is ideal size for front and back? Plus, anything else that is somewhat easy and inexpensive to help out this horse?
Sean 1988 911 Coupe Blk/Linen 1992 Mercedes-Benz 190 2.3 1999 Honda Accord LX 2003 Kymco People 50 (city killer) |
GFCC
What is the intended use of the car? Track or Street or both?
Have a friend depress your gas pedal while you look at the throttle body. Now when he/ she floors it try to move the throttle in the engine bay by hand. Can it move further? If so you are not getting full throttle. Adjust for more power. Also check your full throttle sensor. Does it come on a little past 3/4 throttle? If not adjust it so it tell the DME to go full rich.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
it will be for street and track. I'll have my guy check out that throttle issue.
GFCC
Track size for torsion bars... A lot of guys run23/ 31 (F/R) effective rates for the track. 21/28 for the street. You may want to revalve your shocks if you go with bigger torsion bars. Adjustable sway bars would also be a good upgrade and allow you to have some comfort on the street and allow for more stiffness at the track.
Stiffer sway bars will make your ride more harsh than stiffer torsion bars.
Air Medal or two
TRE strut bar will be the cheapest and most bang for your buck, of all the things I have done so far .......makes a big difference !!
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Super Moderator
The strut-bar will help in keeping the towers from flexing and allowing unwanted camber change but T-bars will have a more dramatic affect on handling. Remember that if you increase your spring rates, you dampening (struts) should also be uprated to match and get the most from your upgrade. Bilstein HD's and Sports are both good choices.
Look at Stop-Tech for the SS lines. I also used Porterfield R4-S pads and I am very happy ith the performance.
Scott _____________ 1984 Carrera Targa 1999 MB E 430 Sport 2006 Chevy Tahoe |
