blown muffler sound?
on the way home from work the engine (1980 SC) suddenly went from a normal note to a very loud exhaust note. almost sounds like my muffler blew out.
it does not appear to be the muffler. the noise seems to come from the passenger side of the engine. it sounds like its not running on all six cyclinders but that may just be my imagination.
i looked under the engine but could not seen anything and i put a wet rag over the exhaust opening and could not hear any hissing. help, this sure does not sound good. any ideas?
thanks,
roger
1980 911 SC
Old 11-15-2006, 07:11 PM
Brew 66's Avatar
Blown exhaust gasket?
2014 X3
2012 A3
1977 GMC C15 Squarebody
1962 Ragtop Bug
1968 Bug (built with my dad, now my daughter's)
Old 11-15-2006, 07:14 PM
you lucked up... I just spent $2500 to get that sound
kidding......check gaskets, or for holes in the system.
Current: 1973 914/4 project. FOR SALE
Old 11-15-2006, 07:30 PM
i appreciate the ideas. hope it is just a blown gasket somewhere in the exhaust system. i will have to wait until tomorrow to explore the situation. it is late, raining, and my wife is watching TV in the living room next to the garage.
roger
1980 911 SC
Old 11-15-2006, 08:33 PM
I had a similar experience a few weeks ago. It turned out that a spark plug had worked its way out. Apparently not an uncommon occurrence. A number of people have had problems with spark plugs backing out. Mine was cross threaded by PO, but yours may have not been torqued down enough. My car sounded exactly the way you describe yours.
cross threaded spark plug on '80 SC
Blown Spark Plug
1979 cashmere beige 911SC Coupe
1980 911SC Targa (sold)
1982 911SC Coupe (sold)
1966 912 Coupe (sold)
1975 914 1.8 Plaid Seats (sold)
Old 11-16-2006, 04:38 AM
19 years and 17k posts...
azasadny's Avatar
When my 2.7L made that sound, it was the head studs that had finally failed. I hope this isn't what happened to your engine!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 11-16-2006, 06:07 AM
mystery of the blown muffler sound solved. i popped the lid and looked along the right cylinder bank and saw the plug wire to cylinder number five protruding out. hum.
the spark plug had backed completely out of the cylinder. like what had happened to snowtire and others on the forum! i guess when i changed plugs and set the valves a couple of months ago i failed to torque number five tight enough. hard to believe they can back out like that.
this time i used my torque wrench and checked the other plugs. set to 22 ft-lb per bentley. i really feel lucky to have such a easy fix. i was afraid the head studs had pulled out. now the porsche is back to making its normal motor music. thanks for your help.
roger
1980 911 SC
Old 11-17-2006, 07:38 PM
It's nice to have something on your Porsche turn out to be LESS expensive than you thought!
Old 11-17-2006, 07:47 PM
azasadny's Avatar
Great news! I'm glad it wasn't the head studs...
Art Zasadny
www.ford.com
Old 11-17-2006, 07:55 PM
