-   -   Compression check (http://forums.pelicanparts.com/porsche-911-technical-forum/31563-compression-check.html)
madster1 08-31-2000 07:24 PM
Compression check
What are the acceptable cylinder compression numbers for 911's ??
Early_S_Man 08-31-2000 07:43 PM
That would kind of depend on what your engine's compression ratio is ... they run from 8:1 to 9.8:1. What engine and compression ratio are you speaking of?
Warren Hall
1973 911S Targa
madster1 08-31-2000 08:03 PM
3.6 liter - 11:1 I believe.
Early_S_Man 08-31-2000 09:48 PM
That is a pretty stout comp. ratio ... My best estimate is that you should expect an average of all six readings to be in the 180 to 225 psi range, and no individual values more than +/- 10% of the average.
Warren Hall
1973 911S Targa
robert ellis 09-01-2000 04:41 PM
When I tested my 3.6 last year at 71k miles the readings were between 178 and 185.
Robert Ellis
90 C4
madster1 09-01-2000 06:50 PM
My readings are 195, 190, 195, 200, 210, 200
Hmm, not bad for 115,515 miles. Huh ??
Early_S_Man 09-01-2000 07:26 PM
Not bad at all! A 198 psi mean value, and all readings within the 10% limit.
Warren Hall
1973 911S Targa
