-   -   Striped my headlight thread at bottom need help (http://forums.pelicanparts.com/porsche-911-technical-forum/315770-striped-my-headlight-thread-bottom-need-help.html)
Cooper77 06-12-2012 03:28 AM
Originally Posted by donporfi (Post 6791404)
I think this is jdbunda´s solution
http://forums.pelicanparts.com/uploa...1339096108.jpg
Hi, after having gone through a similar repair/fix this weekend I can second that the speed-nut option is a good and quick fix. After smoothening the original metal tab in the lamphousing holding the thread I simply mounted a speednut and it was done. Is no permanent fix (permanent in my view is replacing the original tab) - but it solves troubles in the interim.
My 2 cents...
C
impactbumper 04-19-2016 08:47 PM
Bumping this thread to see the angle of the tab on a working solution. Also having difficulties keeping the top of the headlight stay hanging.
donporfi 04-21-2016 07:39 PM
Sorry I do not have the angle of the tab.
You need to make some pressure to compress the rubber gasket and hang the headlight ring to the small tab in the upper part of the headlight bucket.
Craig_D 04-21-2016 09:25 PM
I have a thread on my H4 headlight install that includes how I re-tapped those mounting nuts.
Here's a link to that part of the thread: H4 Headlight Upgrade, from Sugar Scoops
