scott matre
Guest
Posts: n/a
Rear Suspension clunk
Guys, I remember about 1 month ago, a few of us discussed a "clunk" in the rear of our beloved 11's. I mentioned that I thought it might be the spring plate bushings. Well, I have changed them to the Neatrix ones and haven't had another "clunk".. INcedentally, my bushings had worn about 1/4 inch on opposite sides of the pring plate. This was obviously allowing the rear suspension to move around WAAYYYYY too much. You guys might want to check yours.. Just unbolt the cover and check the outer bushing. The wear should be similar on both sides (outside and inside).
Old 09-03-2000, 06:53 PM
