rocker switch under gauges
Anyone know what the rocker switch under the lip under the gauges does (or did) on a 78 SC Euro?
Looks very stock to me.
Current: 1973 914/4 project. FOR SALE
Old 11-30-2006, 06:12 AM
(the shotguns)
berettafan's Avatar
Sunroof on my car if you're talking about the same spot.
Old 11-30-2006, 06:22 AM
i have a targa
Monkey Wrench
Spede's Avatar
If you have power mirrors then it could be the left/right control selector if it is the one between the fuel and oil gauges.
Old 11-30-2006, 06:24 AM
Senior Member
Sunroof switch was placed there on most cars. On Targa's or cars without a sunroof it does nothing but they stuck the switch there to close the hole.
Have seen it used as a kill switch for a poor mans burglar alarm.
Old 11-30-2006, 06:33 AM
(the shotguns)
berettafan's Avatar
Spede i had to steal your avatar....SORRY!
My 2yr old got the movie over Thanksgiving and we have now watched it approximately 19 times. LOVE the 'pit stop' scene and the end where Guido falls over after M.S. talks directly to him. Good stuff!
Old 11-30-2006, 06:47 AM
As Joeaska said, the hole is plugged if unused, and the plug itself resembles a rocker switch but does not move.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Mambodave,
Since we had the same type of original car, I would agree with the mirror selection rocker switch used to control the angle of the side mirror that you selected.
If you post a pic I can confirm this. I've heard from a few people that these switches are prone to failure. So if you can't change the direction of one of the mirrors, it most likely means that this switch has failed.
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 11-30-2006, 07:06 AM
It is in fact the control for the side mirrors...switch left = left mirror...right = right mirror
1984 Carrera Targa
Old 11-30-2006, 03:07 PM
I've got a 78 SC targa there was no additional not used switch installed.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 11-30-2006, 04:09 PM
