floor pan coating - guess the weight
I'm taking a sample of scraped up floor to work tomorrow to get an estimate of how much the coating weighs. I estimate the floor pan coating covers a little over 14 sqft. Anyone care to guess at the weight before I post the data? Does anyone already have this info for that matter?
-Brian
Old 11-28-2006, 08:08 PM
Detached Member
Hugh R's Avatar
I guess 0.25 lbs/sq. ft. or 3.5 lbs total.
Hugh
Old 11-28-2006, 08:26 PM
jwetering's Avatar
Re: floor pan coating - guess the weight
Originally posted by bbh03
... Does anyone already have this info for that matter?
I don't, but I'm scraping mine off slowly and after I scraped off the front passenger footwell area (let's say 20% of the total) into a five gallon pail, I estimated the contents of that pail at 5 pounds. So by my reckoning there will be 25 pounds total - strictly a wild a$$ guess.
Please post your data...I'm curious for sure.
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 11-28-2006, 08:50 PM
Yeah, the fact that it weighed so damn much is what prompted me to do this. It was surprising to me!
-Brian
Old 11-28-2006, 09:17 PM
Priced-out of Porsches.
mmastro's Avatar
I just scraped the interior of my 74 BMW 2002...weighed in at 30lbs even.
I'm guessing 30lbs.
Mike
SoCal
Old 11-28-2006, 09:25 PM
dweymer's Avatar
28lbs
Donnie
Currently Porsche-less.....
Old 11-28-2006, 09:55 PM
Bandwidth AbUser
Jim Richards's Avatar
27.3 lbs +/- 0.5 lbs.
Jim R.
Old 11-29-2006, 05:51 AM
dweymer's Avatar
what's this +/-;
close only counts in horshoes and hand-grenades
Donnie
Old 11-29-2006, 07:20 AM
Results are in:
460 grams per square foot (about 1 lb).
-Brian
Air Medal or two
afterburn 549's Avatar
hmm...my way (weigh) of thinkin is there is a gallon on there total..so what ever a "cured " gallon weighs in at
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 11-29-2006, 09:26 AM
chrisp's Avatar
13 lbs
'83 SC
Old 11-29-2006, 09:33 AM
Air Medal or two
then thats all there is going to be there...if you can smear a gallon on.... and that would be a lot...pretty thick !!
Old 11-29-2006, 10:04 AM
I remember reading somewhere that somebody who'd removed his soundproofing saved all the pieces, weighed them and got 17 pounds. It might have been in Bruce Anderson's book...
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 11-29-2006, 12:35 PM
drag racing the short bus
dd74's Avatar
In which model year did Porsche start using floor pan coating?
The Terror of Tiny Town
Old 11-29-2006, 12:40 PM
lateapex911's Avatar
I did te same when I built my RX-7..came to about 25 pounds. It's one of things you have to think hard about. It DOES make the car better sounding on the street...and the weight is low.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
B D B D is offline
B D's Avatar
I just did this and in my 68 I removed 28 pounds of material, this includes the floor, rear seats and deck. There was easily another pound or so of stuff that went into the vaccum after grinding it down to metal.
68 911L
Old 11-29-2006, 12:43 PM
dd74's Avatar
When I ripped out my interior, I recall coming across a lot of...something. It was sort of gooey/gunky and came up with a spatula. It was substantial, but I don't think quite 25 pounds. Maybe later Porsches received more of it than the earlier cars.
Old 11-29-2006, 02:43 PM
I scraped out the front and rear passenger footwell area insulation on my 87 and it ended up weighing 7.9 Lbs. This ends up being a 1 hour per pound project.
1987 Carrera - GP White
Old 11-29-2006, 02:59 PM
randywebb's Avatar
How much was it total?
Note the other posts are giving info from various areas - when I looked at a '71 it was the stuff 'under' the rear seats that was really heavy.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-29-2006, 05:54 PM
Didn't weight it all, just a sample. The idea occurred to me after I disposed of half of it. My coating was pretty uniform, so if you know the area, you have the whole weight.
-Brian
Old 11-29-2006, 06:57 PM
