Philsy
Guest
Posts: n/a
Fog lamps
Should an 83 SC have one or two fog lamps, and what's the correct mounting position?
Cheers
Old 09-03-2000, 01:14 PM
Superman
Guest
Posts: n/a
Mine has two, under the bumper. Many photos can be found showing the various cosmetic things. '84 and newer ones are mounted back a bit farther and are more buried in the valence. Mine are kinda low and forward. This does a nice job of getting them scraped on even the shortest parking barriers.
'83 SC
Old 09-03-2000, 07:25 PM
campbellcj
Guest
Posts: n/a
You must be asking about the rear fog lamps??? Of course there are two in the front.
Some cars (Euro) had a single rear one, I think on the left side. There is probably a picture in the B. Johnson book if you have that one.
Old 09-03-2000, 08:56 PM
Superman
Guest
Posts: n/a
Europeans drive backward pretty fast, do they? In fog?
'83 SC
[This message has been edited by Superman (edited 09-03-2000).]
Old 09-03-2000, 09:38 PM
CamB
Guest
Posts: n/a
A rear fog lamp is brighter than a rear light when the cars lights are on but not braking (that makes little sense??), so it is easier to see in the fog.
It is important that the car in front has one when you are bearing down on it on the autobahn at speed
My little Peugeot has one, so they must be a pretty common fitment in Europe (possibly legal requirement, cause the Pug is truely base model).
Cam
Cameron Baudinet
1975 911S
[This message has been edited by CamB (edited 09-03-2000).]
Old 09-03-2000, 10:14 PM
mikez
Guest
Posts: n/a
If you need a pic of the rear, red fog lamp on a european delivery 911, I can send you one....
Mike Z
83 Cab...euro.
BTW, the fog lamp is a good idea in foggy areas....that lamp really shines and when you are doing warp nine down a well marked autobahn in the heavy fog, a bright warning light is a good idea....at least if you are the guy in front and some moron is doing warp 11.....8^)
[This message has been edited by mikez (edited 09-04-2000).]
Old 09-04-2000, 12:06 AM
Philsy
Guest
Posts: n/a
Mike Z,
Yes, I'd appreciate a pix. I suspect that the one on my car is non-original, it's also mounted very low and gets knocked.
Rear fog lamps are a legal requirement in the UK, I'm surprised they're not in the US. They're a good idea so long as people use them properly (ie in fog), there is a tendency for them to get left on thus annoying people behind.
Old 09-04-2000, 12:35 AM
