Question for the "Oil Leak Pros"
I have replaced all the oil return tubes, New Upper and lower covers, gaskets, nuts and crush washers,, does this leak look like it is coming from the rocker on #4.. You can see the oil on the nut and on the side of the cover just next to the heat tube This is a 69T
usually the cam thrust plate gasket or o-ring. see the drip on the aluminum piece to the left of the cover. the tensioner shaft in the cover could also be loose.
That piece to the left of the cover seems to be where it comes from when I can first really see it..
John what is the procedure to fix this? Thx
