-   -   Frequency valve not buzzing 83'SC (http://forums.pelicanparts.com/porsche-911-technical-forum/315976-frequency-valve-not-buzzing-83sc.html)
Scott R 11-28-2006 07:48 PM
Originally posted by Vin-barrett
Hiya Scott
When I checked the voltage at the FV connector I am taking the pulsed ground out of the loop - correct?
In other words I put one probe of my meter to one of the FV connector's terminal and the other grounded right to the engine. This is where I am getting the 8.5 volts.
Like you said about a temporary line going around wiring issues.
I'm thinking running a long wire from terminal 87b at the relay under the seat straight to the FV to see if I get anything greater than the 8.5. I'm not sure what the voltage should be either.
Yes correct measured from an engine ground. It is strange that your getting low voltage. I know from testing injectors in the past that you need pretty close to 12V to get them to crack.
I suppose you could have corrosion in the CIS electrical connector aft of the FV valve, or somewhere else. It's a pretty short run from the relay to the flat black plug.
Good luck!
Lorenfb 11-29-2006 06:36 AM
Check here for the FV signal waveform:
www.systemsc.com/waveforms.htm
and then use a scope to verify that your Lambda unit is functioning properly.
