-   -   Condensor mounting advice (http://forums.pelicanparts.com/porsche-911-technical-forum/31607-condensor-mounting-advice.html)
jimtalSC 09-04-2000 09:59 PM
hi,
I'm about to reinstall aircon in my 911. With everything that I've read about early aircon systems in 911's I want to make the exercise worthwhile, I want cold air.
Appreciate any advice regarding placement of aircon condensor. i am planning to mount a condensor and fan unit in the left front gaurd, and install a new washer bottle.
I'm aware that small condensors are often mounted under the chin spoiler or underneath the car however i thought that by placing it in the gaurd I would be able to place a larger condensor and fan, greatly increasing the efficiency of the system.
I live in Australia and it gets awfully hot down here so I need a system that really spits ice chips.
Let me know what you think. Anything that i should be aware of that I may not have considered.
Regards
Jim
michael3001 09-05-2000 03:50 AM
I'm like you the colder the better. Here in S. Florida it's hot + humid.I'v tried fans on the existing condensor"s (rear and front)and found a fan placed on the rear condensor doesn't work' I got higher temps when on, because it interfeared with the motor's fan(the alt. 11 blade) and I removed it. I now run with an additional under the floor pan condensor(it's large)and I'll get temps in the 50's all day long,even better when the sun is not high in the sky. I removed some of my front Valance and got it (condenser)in the air stream. After I cleaned -up my evaporater(79sc.)my machanic sprayed it with some caustic liquid,(smelled like batt. acid) the improvments were very noticable.
beetos 09-05-2000 04:46 AM
Michael,
Can you go iinto a bit more detail on the additional under floor condensor. Where did you get it and where exactly did you fit it.
juan ruiz 09-05-2000 04:04 PM
On my 88 911 i install 2 small fans under the condensor and are wire up to the compressor temp drop 20 degress, engine temp normal.
jimtalSC 09-05-2000 05:14 PM
Juan,
Are you talking about your rear condensor or the ones at the front?
Jim
juan ruiz 09-05-2000 05:34 PM
Jim ,the rear one under the tail
Graeme Block 11-26-2014 04:38 PM
Thermo fans
Can someone give me information about the Thermo Fans to be fitted to the rear a/c condenser. Supplier and part number or size dimensions.
