-   -   Does it matter which rotor i get for distributor on 72? (http://forums.pelicanparts.com/porsche-911-technical-forum/316084-does-matter-rotor-i-get-distributor-72-a.html)
berettafan 11-20-2006 05:43 AM
I noticed Pelican has several rotors available for the longhood Bosch distributor. I don't know which i have and need to get my order in this morning if possible.
Is the only difference in the rev limiter?
Motor is a '72T w/ webers and supposedly 2.2S pistons, cams etc.
Thanks,
Erik
Joeaksa 11-20-2006 05:59 AM
There are several flavours available for this application. Rev limiter is part and there are versions that are plain rotors, that is without the rev limiter built in.
Would try to limit rev limits to 6200-6400 and no more unless you are sure that the engine is in good condition and descent parts inside.
berettafan 11-20-2006 06:09 AM
No problem limiting rev's to 6.2 i'm just wondering if there are any other differences in the rotors. Thanks!
real550A 11-20-2006 06:53 AM
If rev limiting rotor is not needed, try a '74 Beetle. Works great!
