Measuring front sway bar size?
Sounds simple, but??
I need to order new bushing for the front of my 65 911. I measured it and it is 13mm, the square ends are 17mm. In the catologs they have 16mm, 19mm and 22mm?? So which ones do I get? Thanks for any help.. Bruce |
No stock bars from that early were 19 or 22mm, so you can rule those out.
Actually, just to confuse matters further, I am pretty sure the early bars are 15mm, even though the bushings are listed as 16mm! You may want to call a tech guy at Pelican Parts or Stoddard to verify what you need...they can check the factory parts manual. |
| All times are GMT -8. The time now is 09:27 PM. |
