Flag Mirror Motors into Aeros??
Anyone ever put their flag motors into aero mirrors?
I just thought I would ask before I cut any wires.
Also the wires on the drivers side for my 78 are different colors from all of the schematics that I have seen on here.
Any one know which wire connects to which between the 78 and the 993, Thanks J.
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 06-14-2006, 06:14 PM
Tough questions as the wire colors vary within certain years. Since I've been keeping track I have heard of, but have not seen, a direct wiring scheme for SC/Carrera mirrors to any aero counterpart. I also believe the motor assemblys to be completley different as well.
Can you post the wire colors as the come from your door?
Warren & Ron, may you rest in Peace.
Old 06-14-2006, 07:13 PM
From Door I have Grey/Green, Black/Yellow, White, Blue, Brown and Brown.
Connected to those from the mirror are;
Grey/Green, Black, White, Blue, Brown, Brown.
I have not yet looked at the Pass side yet.
Jeremy C.
-2001 996 Turbo
Old 06-14-2006, 07:25 PM
JCC, I'll look at my references in the morn and post back.
Old 06-14-2006, 07:29 PM
Thanks for your help. Did you ever find any more of your modules? Or are those for Carreras (mid-late 80's)?
Jeremy C.
-2001 996 Turbo
Old 06-14-2006, 07:38 PM
The modules are for SCs and Carreras. However there are wiring differences. I did find the extra set.
FWIW, I'm thinking of doing a tech type article on DIY module/wiring.
Old 06-14-2006, 07:43 PM
Thanks, I would love to read it!
In looking at your modules, the connectors are long and norrow, whereas the connectors inside my mirror are round. How do the two jive?
Jeremy C.
-2001 996 Turbo
Old 06-14-2006, 07:48 PM
The "module" merely connects via soldered butt joints...not sure what you mean.
Old 06-14-2006, 07:52 PM
Not the module itself, but rather the white connetor, I believe is is the female end I have seen in your pictures. The shape of it is rectangle, but where the door and mirror wires connect inside of the mirror is a round connection.
I guess I may not fully understnd how the module works. Is that extra set for sale?
Jeremy C.
-2001 996 Turbo
Old 06-14-2006, 07:55 PM
Banned
Call BW Motorsports,(618)622-0524, they have the right modules for a hassle free install, cheers, Ant.
Old 06-14-2006, 08:19 PM
I will look for the extra set and PM you. The connectors you see allow the existing harness to connect to the mirror with a factory connector via the relay module.
Old 06-15-2006, 06:54 AM
Rick, PM Sent, Thanks.
Jeremy C.
-2001 996 Turbo
Old 06-19-2006, 09:21 AM
everyone here has been discussing wiring differences- but you can't use the internal guts of the early flag mirrors in a late aero mirror- very different designs!
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 06-19-2006, 09:39 AM
"I also believe the motor assemblys to be completley different as well."
This is why we're discussing the use of the relay.
Old 06-19-2006, 09:57 AM
wesayso's Avatar
Sorry to bring up this old post but what type of relay should I be looking for in hooking up aero mirrors to my '82 SC? After reading most of the older posts I guess the relay wil be 'activated" by the wiring that goes to the clutch in the old mirrors to switch from up/down to side/side action or vice versa? A source for those factory connectors would be great too!
Unless the module can be bought easely through the net, I'm in the Netherlands, Europe, so I'm looking for a place to source the parts or the wiring kit with the relays as a whole.
Thanks,
Ronald
'82 911 SC
Old 11-09-2006, 02:45 PM
I purcahsed a set from Rick M, but I am not sure if he makes them any more. Otherwise I beleive that Performance Products carries them.
Yeah, I beleive the orginal motors use reverse poarity to change directions. This will not work with the new motors.
As for factory connectors, I am not sure where you can get them. Since my connections were round and the relay connections were square, I had to cut (I know ouch) the doors side and connected 0.69 (i believe) male pins to the wires. Some of the wires had to be piggy-backed together. If you find a wire schematic (shearch here) you will figure out which wires connect to which module wires.
Hope this helps, Jeremy
Jeremy C.
-2001 996 Turbo
Old 11-09-2006, 03:18 PM
wesayso's Avatar
Thanks for the reply. I didn't find any at Performance Products, I'll keep looking. Maybe I'll PM Rick M for some help, couldn't hurt right?
'82 911 SC
Old 11-14-2006, 12:54 AM
modules
If you have the holiday catalog, they are on pg. 213
The part number is 913145.
Good Luck!
Jeremy C.
-2001 996 Turbo
Old 11-18-2006, 06:35 AM
wesayso's Avatar
Thanks, that helped a bit but I only see the modules complete with mirrors. I think I can find a way to make it work using a relay like in RickM's picture. The factory connector in the mirrors I bought were actually VW-Audi parts so I'll try to get 2 of them to keep wiring original inside the mirror. I believe my left mirror has a temperature probe as well but I wouldn't know how or where to hook that up.
Thanks for your help!
'82 911 SC
Old 11-20-2006, 12:35 PM
Thats odd, because in my catalog, the listing says,
Electric Wiring Module for Aero Mirrors 911 78-86 1pr.
Jeremy C.
-2001 996 Turbo
Old 11-20-2006, 03:43 PM
