I have a 77' Carrera 3.0 engine in my 74. I need to replace the CIS line between the Fuel Distributor and the WUR.
I wanted to check if the metal SC line is a direct retro-fit, or is there more fittings involved to get it there? On the C3, the WUR is just like a 2.7L and the FD is pretty darn close. Thanks
John F. Lewis 74' 911S Targa + 930/02 76' 914 - Eternal Type IV project FOR SALE |
I'm interested in this too. There had been posts about sourcing nylon tubing from McMaster-Carr that would work well, but I forget whether it was a definitive solution.
Art '75 911 US Carrera #390 '74 MGB, AH 3000 BN7 V8, '65 Mustang Fastback, 66 bronco U13 |
The WUR side is fine, but at the fuel distributor you need the fitting from the FD to the hard line. I may have one if you need one.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Yeah, if you have one that would be great. If you have the entire line that would be even better.
I figure the WUR on the C3 is in the same place as the SC so that the metal line works. Attached are the pictures of my C3
Yea, that's the same location. I sold the line as part of a set, however I think I have some of the fittings left. When I get a chance tonight I'll take a look.
Yes, you can retro fit the later 80-on metal lines on a 78-79 3.0
You can order all the line from Porsche direct, go through a dealer ship part #'s for hard lines 930-110-485-00. 486,487,488,490, one of these can be used twice, can't remember which one you need 9 seal rings, 900-123-115-30 |
