-   -   1987 911 color need help (http://forums.pelicanparts.com/porsche-911-technical-forum/316419-1987-911-color-need-help.html)
jhubs 11-21-2006 10:01 PM
I just purchased this dark blue, 1987 Porsche 911 and I want to buy some matching touch-up paint. The touch-up paint that came with the car, Marine Blue Metalic, is too dark. I can not find any place on the car body or any sticker with a color code where the color is listed. Any ideas?
jhubshttp://forums.pelicanparts.com/uploa...1164174947.jpg
Thanks!http://forums.pelicanparts.com/uploa...1164175178.jpg
Garen 11-22-2006 06:36 AM
Here's my 930, which according to the sticker on the pass side in the front luggage compartment, is marine blue. The pictures of my car were taken on a cloudy day, but it looks like we might have the same color, especially since your's is also a 1987.
Hope it helps...
-Garen (87 930)
http://forums.pelicanparts.com/uploa...1164206181.jpg
http://forums.pelicanparts.com/uploa...1164206202.jpg
stormmaster 11-22-2006 06:37 AM
Looks like my marine blue one.....touch up paint is often not exact match....I suggest going to a paint supply store with a part removed from your car to see what will work. I have some duplicor touch up paint used for an american car that works well for me for minor touchup...
KFC911 11-22-2006 07:46 AM
Don has a great suggestion. I ordered some touch up from paintscratch.com for my '88 Diamond Blue Metallic, and although it's 'close enough', any decent paint supply store could do just as good.
jhubs 11-22-2006 09:03 AM
Thanks guys,
I peeled back the trunk liner and found the color sticker and it is exactly the same as the one in your photo, Garen. I've only been a Porsche owner for 9 days, but I'll bet that the easiest part to remove to take to the auto paint store would be the headlamp trim....correct?
Thanks again!!
jhubs
KFC911 11-22-2006 09:09 AM
Many folks use the gas filler 'lid/cover' as a painted part to 'match'...
KFC911 11-22-2006 09:11 AM
Also, in case you weren't already aware, the 'metallic' colors also have a 'clear coat' on top.
jhubs 11-22-2006 09:25 AM
Thanks Keith, The fuel cap it is! Yes, the paint I have has a bottle of clear coat with it. I'm going to really shake up the paint, paint it on a piece of dark cardboard for a test, and see if the metalic particles will lighten up the paint a little and then put some of the clear coat over it too. THANKS!
jhubs
