randywebb's Avatar
older upper valve cover
stamped 901-105-116.0R
anyone know if this is Al or Mg?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-22-2006, 10:19 PM
pwd72s's Avatar
Fraid I don't know by part number Randy, but the metal color should tell you...mag is gray, aluminum quite a bit brighter...
Old 11-22-2006, 11:27 PM
randywebb's Avatar
thx Paul, but it is all black... inside & out -- not even a scratch on it to see the metal
maybe some paint will flake off after I finish running it thru the dishwasher...
Old 11-22-2006, 11:34 PM
MBEngineering's Avatar
HI if the R/Cover is painted black then it is more than likely it is mag', as the ally' was not painted, the other way to check is to put a strait edge across it and see if it is warped, if it is, it is mag.
regards mike
Old 11-23-2006, 05:15 AM
