door mechanism
Last month I replaced my window regulator on my driver side door as it had corroded. I also manage to fix the faulty passenger side window switch that is on the driver side door. I was pretty proud of myself (2 birds with one stone). Anyway I got in for a drive after it was layed up for over a month and when I attempted to get out, the inside door handle on the drivers side wont open the damn door now. I have to roll down the window to use the outside handle. I thought everything got put back together the same way it came apart. Does anyone have an exploded view or a tip on what might have become discombobulated? Thanks
Old 11-25-2006, 05:56 AM
Diss Member
Quicksilver's Avatar
You should put your model and year of car in your signature so we can tell what type of car you are working with.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-25-2006, 07:48 AM
Is the interior handle loose? If so, it might not be connected to the door mechanism link. Take a look.
Otherwise, remove the door panel and take a look at the linkage between the interior and exterior handles. Something is loose, broken or disconnected between the two.
Hope this helps,
Sherwood
Old 11-25-2006, 08:13 AM
Hows that?
Old 11-25-2006, 10:21 AM
Somatic Negative Optimist
Gunter's Avatar
Is the small steel actuating rod connected to the tiny plastic clip in the handle?
Bentley SC Repair Manual 570-3.
Get the Bentley, you'll love it.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 11-25-2006, 11:15 AM
