Zombie
High Oil Pressure Reading?
Having recently changed my oil in my 87 carrera, I switched from Mobil 15w50 synthetic to 5w50 synthetic. The reason for doing this was at the recomendation of my mechanic due to a variety of temperature ranges. Now while driving I get a higher than normal pressure reading then before. ie(3500+rpm = 5bar) Is this due to the lower weight of the oil? I know a high pressure reading is ideal but this doesn't seem right!
T-RONE __________ 87 carrera coupe |
My guess is the high oil pressure is due to the lower air temperatures.
Does the higher oil pressure drop after driving for 30 minutes? After the oil warms up it should be the same as before the oil change.
Jeff 1981 911SC Coupe - SSI's + Dansk, MSD, AC delete, Heater Backdate, Euro ride height, polygraphite bushings, Rennshift 1998 F-150 4x4 - Snow Time 1998 Yamaha WR400 - Mountain Ride |
Zombie
No, the oil pressure remains high even after 30 minute drive.
T-RONE |
Zombie
BUMP
I am not sure how much psi 5 bar equates to, but my oil pressure is usually double of the rpm. On a normal day at 3500, oil pressure would be around 60-70 psi. If it is a really hot day, I will see about 40-50 psi. Theoretically, pressure should be slightly lower by switching from 15W to 5W. Are your thermostats working correctly? Is oil temp normal as usual?
'75 911S Silver Anniversary #164(Formerly JTO's) Rebuilt 2.7 with full ARP, 9:1 CR. SSI, GHL, ER polybronze bushings, finned oil lines. Lowered and corner balanced. CIS retired, now PMOs! '65 912 slate gray sunroof (driving project) |
Somatic Negative Optimist
T-Rone: Still driving now in Edmonton? Isn't it time for winter storage?
Any way, most people do not use synthetic because they found that the oil/air cooled engines in a 911 leak less with Dino oil. I go along with that. Use synthetic in water-cooled engines. For me: 15W40 Dino in the Spring and Fall with good results. I like 15W40 because it's a Diesel application; high pressure stuff. In the Summer: 20W50 Dino for me. As for your higher pressure reading: Thinner oil should get you a slightly lower reading. Unless I am missing something. What is your pressure at 900 RPM? It should be about 1 bar, slightly under.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Zombie
Thanks for your input everyone, Dr. Gunter this was just an observation I made before winter storage. I just now found time to post.
As for my pressure reading, it is about one bar @900RPM but anything over 3k it pegs out at 5 bar. T-RONE |
3.4 Bigger is better
I did a rebuild last year and my oil pressure at anything over 2700 rpm is pegged at 5 bar. This is the same as before the rebuild. Sound about right IMHO.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Detached Member
Are you sure your gauge is actually working. Does it ever go below 5 bar, or is it pegged. If pegged, (i.e, when ignition on but not running), then you'd have an open connection to the sending unit.
Hugh |
Zombie
Hugh, the guage is working properly. Once over 3k it is pegged then it drops when rpms fall. I've read some other threads, maybe I'll try cleaning the faston tab and go from there.
T-RONE |
Are you using the cam line restrictors?
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
